- Thomasville, GA
I've been looking for information online in stepper driver forums for an issue that came up, so here I am in a woodworking forum hoping one of you geeks can assist.
I'm using DRV8825 drivers. The issue is related to R4 in this diagram:
When I apply 12VDC power to the RAMPS1.6 board with a driver plugged into its socket, R4 immediately starts burning, so I disconnect power. The only thing attached to the board is the Arduino and 12VDC power; no power applied to the Arduino, except via the RAMPS. The same thing happens on a second set of boards with the Arduino powered via USB and 12VDC applied to the RAMPS.
The strange thing about this is I did not have this issue on a RAMPS/Arduino set that I was installing on my 3D printer. I bought a second set of boards to be able to investigate an issue with the display fading out with drivers installed on the first set.
With all this happening, I'm concerned about blowing up more drivers. Any thoughts?
