Chuck Ellis
- Tellico Plains, Tennessee
One of my fellow vendors at the Museum Marketplace dropped off a few pieces of a cherry tree he had cut... there were a few little burls on the wood...
These 3 bowls are from the main portion of the log.... I cut the log to size, turned the big bowl, then using my Woodcut Coring attachment cored out two more bowls.
The big bowl is 9 1/2 inches diameter x 4 inches high, second is 8 1/2 diameter by 3 inches high, last baby bowl is 5 1/2 diameter by 1 3/4 inches high. I don't measure volume as Dave Hoskins does, just diameter and height of the rim. Finish is an abrasive grit, with 2 coats of sanding sealer over, then multiple coats of wipe on poly.
I also don't use a diffused lighting as I should so you can see the light bar over my desk reflected in the bowls.
