The legs are all glued up, pretty close to my original mock up.
Taking a coffee break then finish up the slabs. Can’t wait to dry fit it all together hopefully tonight. I took the plunge and ordered a hvlp sprayer system, I think to spray a clear finish I will spray the legs prior to final assembly. The top will bolt on the bottom shelve I was going to glue the center only. I could put a blank in the dado to keep the finish out. Have a few days to think it over. Saturday I hope to make it shinny.
Someone messed up my shop, can’t find enough floor space for all three pieces. Pretty happy with them can’t wait to get them shinny. Once I get the shop cleaned up I should get better pics.
Hi Ted I got the fugi semi pro, a two stage (customer service outstanding had a broken part from shipping new one sent within 24 hours) I found it has a bit of learning curve the bottom has a bit orange peel effect but as my confidence gained and the settings the tops turned out great. Lessons learned thinning, how fast to move ect. Not disappointed, a four stage turbine would be neat but not in my budget.
For the past several years I've been using a gravity feed HVLP 'conversion' gun that I got from Jeff Jewitt at Homestead Finishing. With a 1.2mm tip it works great for Target EM6000. A 1.5mm tip also works great for Em8000cv and also the EM1000 sanding sealer. I think I paid around $250.00 for the gun kit with three tips.
Interesting design choice to have the lower shelf set between the "feet" rather than one level up between the legs as a stretcher. What guided you to make that choice?
The design idea roughly came from a table I seen on Pinterest, I looked at different options for the bottom shelf but I liked how it looked. It’s definitely different I think that’s why I like it.
