Do you have the metal in and out feed tables? They make a difference, and they are adjustable. I also have my 735 mounted on a miter saw/planer stand that has additional in and out feed rollers that I can extend out further to better support longer boards. My stand is a Delta, but an improved model is available from DeWalt. This stand, when folded, wheels around like a hand truck and will store on it's end in your shop with the planer attached to it. The two large diameter wheels make it easy to go over bumps and raised door thresholds, down ramps too. When needed, I roll it and the planer outside in my driveway to do planning (shop is too small). Lifting into position is assisted with built-in gas springs. Lifting slightly and then releasing a latch then allows folding, again with gas spring assist to lighten the load, and I pick up the handle end and wheel it back into the shop where it again sits on it's end in the corner of the shop until needed again. At 81, and with metal knees and heart problems, I can still easily move and set up my 735 this way, but I can no longer lift it by itself off of a workbench without help. 95 lbs is beyond my abilities now.
The significant difference between this stand and my Delta is the single post under each outfeed roller. My Delta version has 2 smaller posts, under each roller and adjusting the roller height causes racking much like pulling an unguided drawer in and out. The single larger post of the DeWalt works better, and I would replace what I have with the DeWalt if the cost wasn't so high. For me, I'll likely continue using what I have and fussing with the jamming roller height adjustment. The only other significant difference between them is the color. Otherwise, they are identical.
With the metal in and out feed tables, plus the in and out feed rollers of the stand adjusted properly, my DeWalt 735 planer snipe is so little that I can see a faint line on the work where snipe would be, but a couple of swipes of 100 grit sand paper make it go away. It's only a few thousandths difference.
I did need to make an adapter, a piece of 3/4" cabinet birch ply with mounting holes for the planer, then a second set of mounting holes to attach this adapter to the mounting rail spacing on the stand. It was easy to make and the planer has remained attached to the stand via this adapter since I put them together. You will likely need to do this for this DeWalt stand too, since the rails are positioned more for mounting miter saws and not the 735 planer, which is much wider and needs to face sideways to the stand.
The DWX726 Rolling Miter Saw Stand is a convenient solution to transporting a saw between jobsites. Constructed of steel for durability providing 300 lb capacity. One-time assembly and pneumatic ...
www.dewalt.com
