- Springfield, Missouri
About 7 years ago I set out to automate my dust collector by having it automatically turn on/off with the tools I used it with. I didn't want to run a bunch of wires to every tool and given my DC was located next to my electrical panel, I went with sensors on each circuit with tools and turned on the DC when the amperage draw was over a certain threshold. Here is a demo of that system.
It had it's draw backs. I had to remember to open/close the gates. I had hand tools that I wasn't connecting to the dc that I plugged into the one or more of the circuits that often toggled the power on to the DC when it wasn't needed. I had added a main switch that I often forgot to turn on when I needed to use the DC.
Fast forward a few years and components to build my ideal system have become more affordable and I've learned a few things about designing and engineering a better mouse trap.
My goals for the new system were:
The sensors can be setup for single phase 110v & 220v, and theoretically 3 phase tools.
It's wifi connected, so I can configure the threshold values and see reported sensor values from a web page on the controller. I plan to add more configurations to it over time, possibly to control additional remote gates. I'm also working on adding a bin sensor to alert me if it's nearing full.
Here is a demo of the sensor side:
This is the sensor communicating with the controller side:
This is a demo of the sensor with my sander. I've simply plugged in the sensor, the sander into it, and waited about 30 seconds for the sensor to sync up with the controller. Listen closely and you can hear the DC kick on, then you can hear the DC running in the background once the Sander is powered off. I turned off the sander, you'll see the light start to flash as the lines are cleaned out, then when the sander is turned back on, the light goes solid again, then I power off the sander and allow the system to shut down.
I've only got one gate connected, but I have connections for two gates at each sensor, both will open at the same time for tools that can utilize multiple ports (table saw, router, etc). Also multiple tools can be used at the same time, so I could be working at the Table saw and the cnc can also be running, the last tool off will turn off the DC. If manual control (button pushed) is done, it over-rides any tool sensor and stays on until toggled off by the same button.
For the safety side of this. I'm planning to power the relay from my lighting circuit in the shop, that way the DC can't run if the lights are out.
I'm currently assembling more sensors and adding motors to gates.
- Easy to install
- Easy to setup and configure
- Easily expandable
- Add automatic control of dust gates
- Have manual control of the DC at each tool
- Have visual indication of what tool sensor is running the DC and its status
- Have remote control of the DC
- Able to have more than one DC system (which I do).
