Toni Ciuraneta
- Catalunya
Hi guys.
Most likely the idea is not new, but having the need of routing an arch in my next project (wait and see), and not having a circle routing jig, I came up with this simple jig.
The pictures are self explanatory, or so I think. Basically one of the screws act as a pivot point and the other lock in place the end of the bar that gets into the router where the bars of the side fence are attached.
You change the radius by loosening the router bolts that hold the bar not the one on the jig. The jig spins around the non threaded part of the screw that is the pivot point
You only need a steel bar of the same diameter of your router side fence bars and a small piece of hard wood and two screws.
The fact that neithe the bar nor the pivot poit are aligned with the router bit center doesn't matter, because there will be a virtual line from the pivot point to the bit.
Should you want to do it a bit more sophisticated, you could use two bars, and the piece of wood holding them, then the pivoting screw would be placed in the center of the wood and aligned with the center of the router.
