- Constantine, MI
I made this mahogany table for a client 2 years ago. It is colored with trans tint dye and top coated (IIRC) Rock Hard solvent base.
The finish is failing on several levels. As you can see here, the finish is flaking off at the edges of the table.
It is also flaking where the breadboard end meets the table top.
Before
And after
Finally, it has a tendency to scratch very easily.
One last thing - nothing to do with the finish I think, there is a ridge that has developed where two of the boards meet in the glue up.
My guess is that I have no choice but to take it down to bare wood and refinish it. I've already let the client know there my be a small change in color as I will need to mix a new batch of dye and my record keeping sucks.
Apparently, so do my finishing skills as I believe the finish is not failing as much as it is something I did wrong.
I am hesitant to use the same finishing method and am considering finding someone local that can spray it with a lacquer for me. If not, maybe switching to a water base finish. Any thoughts along these lines would be appreciated.
Lastly, what about that ridge? Does this happen to any of you? Remedy? Card scraper and sanding then hope it does not reoccur?
Before
And after
Apparently, so do my finishing skills as I believe the finish is not failing as much as it is something I did wrong.I am hesitant to use the same finishing method and am considering finding someone local that can spray it with a lacquer for me. If not, maybe switching to a water base finish. Any thoughts along these lines would be appreciated.
