larry merlau
- Delton, Michigan
when using a spray gun you need to adjust your gun for the various finishes and adjust the spray pattern.. well card board isn't always available to me so. i came up with this frame and covered it with rosin paper which is used under flooring sometimes to avoid squeaks.. well a 20 dollar roll will last a long time,, and give you plenty of area to dial in a gun to the finish your using.
