Chuck Ellis
- Tellico Plains, Tennessee
I finally got a picture of this bowl that I've started.... it's still in the process of being finished... sitting on my paint points with 2 coats of SS and first coat of Polyurethane....
The bowl is about 11" diameter by 3" high (about 2 1/2" deep)...woods are spectraply, black limba, aspen and I think a piece of cherry....
I glued up the block to cut for pepper mills, but decided to try my hand at a segmented bowl...
These two are from the corners of another block glued up for pepper mill... I cut two blanks out of the center, then glued the corners back together... the new block was big enough to cut two blanks for small bowls... these are about 6" dia by 3" high... again about 2 1/2" deep.
The woods are spectra ply, Aspen, black limba and bloodwood. Also in process of being finished with my normal finish, sanding sealer and polyurethane.
Then I had the corners of the blank where I cut the circular blank that I cut into bottle stopper blanks...
