Yes you did.
I'm not sure what the original planned use for the pot was for, or why you bought it, but a few vacuum pods attached to your work bench and lines run from the vacuum pump to them will make a great vacuum hold down for routing, sanding, etc. I do this, but paid about $100 for my vacuum pump and another $60 for the Rockler vacuum pods. You can make vacuum pods yourself in most any shape and size. The readily available 100 mm hard plastic tubing and some push insert 1/8" brass pipe fittings will adapt the pads to the hose and your vacuum pump, and these fittings release the hose just by pushing in the ring around the tubing in toward the fitting. No tools required to change the configuration. One of those disposable inline paint spray filters connected inline to keep sawdust and debris out of your vacuum pump, and you will be in business.
The pods are just a groove in a solid piece of wood or plastic with a large O-Ring 2 inches or more in diameter that fits in the matching groove. When installed, this O-Ring needs to sit partially above the surface, so it seals well to the work piece. A 3/8" center hole about 1/2 way through this piece that intersects with a horizontal hole makes the vacuum passage. This horizontal hole can go from one side through to the other, for attaching additional vacuum pods, or only 1/2 way, if it will be the last vacuum pod in a string. Rockler sells, or has sold these pods made from plastic and they work well. You can make irregular shaped seals using closed cell foam Weatherstrip too. The larger the area inside the O-Ring, the stronger it will grip when vacuum is applied, if there are no leaks. It's amazing how strong even the 2" vacuum pods can hold a work piece. A ew seconds after switching off the vacuum pump, your work piece will be released as if it was just laying there waiting to be picked up. With the vacuum on, you will likely lift the work bench by lifting up on the work piece.
This link should get you started -
https://www.google.com/search =rockler+vacuum+pods&rlz=1C1CHBF_enUS814US814&oq=rockler+vacuum+pods&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yDQgCEAAYhgMYgAQYigUyBwgDEAAY7wXSAQoxMzQ2NWowajE1qAIIsAIB8QXYIzHTktTkdPEF2CMx05LU5HQ&sourceid=chrome&ie=UTF-8
