Hackberry Popcorn/Serving Bowl
Dave Hoskins
Parker County, Texas
Finished this one up late this morning. It's 12 3/4" diameter, 2 1/2" high, 1 3/4" deep at the center and 2" at the bottom of the trough for unpopped kernels. It holds 3/4 gallon measured to the brim. The first two photos show it holding one bag of nuked popcorn. Probably will hold two if you wanted to. The wood got two coats of walnut oil for sealing. Finishing was done with shellac with a bit of walnut oil based wax mixed in.
Thanks, guys! The hackberry logs I have right now average about 18" in diameter. I've had a lot bigger but not from this tree. Don't know anything about huckleberry except from Mark Twain. Might be what your thinking on Paul.
Huckleberry.... Like Dave I knew about the reprobate Huckleberry Finn.
I knew that they existed but had never seen any or had any food that incorporated huckleberries until very recently. Our next door neighbors went on a grand tour driving all around the country. They put like 12000 miles on the car during this drive. I would have been saddle-sore..
While they were in South Dakota they had car trouble and had to spend a few days on foot. This gave them time to do some shopping for souvenirs for friends and neighbors. They are kind and generous like that. We were the beneficiaries of two souvenirs and both involved huckleberries. The first was coffee infused with huckleberry oil. Can't say much for that as we didn't care for the flavor in coffee. The second was a pint jar of huckleberry jelly. Good stuff!
And that is all I know about huckleberries which is a lot more than I knew a couple of weeks ago.
I know nowt about turning, but I do like that wood.
Dave, is it hard, soft, or porous?
btw..will be coming thru your area in about 10 days :)
To me it is a soft wood. Not as porous as cottonwood, but it usually takes 2-3 coats of walnut oil to soak in and seal it good. The trees get taken down all the time by high winds due to the softness. Whenever we have some real high winds I can usually count on getting more of it. You don't want a hackberry near your house or other structures. You might end up with one on your roof. Too bad as they are a decent shade tree. Where are you going, Bill???
