- Constantine, MI
When we moved here 8 years ago I had plans of erecting a shop building - plans that were quickly an rather unceremoniously dashed by the local zoning official. Long story, suffice it to say I really dislike our realtor. Anyway, the existing garage became the shop leaving me with a lot of yard equipment, shovels and rakes and implements of destruction to store. So, I built a shed.
I made two critical errors. One of which I could have gotten away with if it were not for the second, which I knew about, but presumed I would fix before it became an issue - I did not.
The first mistake was using OSB for the flooring. Bad choice, should have been treated plywood. Even so, I could have managed were it not for the second, and more grievous error - a P-poor job on the thresholds. The pictures tell the story - water is not being shed properly and is running back into the shed and rotting the floor at the corners of the doors. I'll be tearing up 2 4x8 sections of floor and replacing them with the aforementioned treated plywood. I'll also need to replace the trim on the sides of the overhead door. My dilemma is this - how to treat the thresholds, especially the one for the overhead door.
I believe I can find a better threshold with better design to encourage run off for the entry door. Some self adhering rubber membrane should also help. The overhead door is a whole 'nuther story. As best I can tell there are no thresholds that will reach out over the exposed floor as this type of door was meant to close against a concrete pad. I've toyed with the idea of fabricating one from PVC, but unsure if it will work.
So, I know many of you have construction experience well beyond my own. Any thoughts?
Overhead door
Entry Door
Overhead door
Entry Door
