Mike Stafford
- Coastal plain of North Carolina
The next time you are in the Amazon jungle and happen to cut yourself with your machete severely enough to require stitches you should look around for some army ants.
Not just any army ants but the warrior army ants. They are easily recognized by the large mandibles which are used to defend the ant colony from predators.
These warrior ants can be used as stitches/sutures. Just grab the warrior ant by the body and position the mandibles so that they on both sides of the laceration. Press the mandibles against the skin and almost immediately the ant will close its mandibles and pinch the skin closed just like a suture. Then you just twist off the ant's body. Apply as many ants as necessary to close the wound.
These warrior ants will attack virtually anything they can grab so this is an ant species that you definitely don't to find in your pants.
Stay tuned for more useful information.
