Lacquer sanding sealer
allen levine
new york city burbs
Can I spray sealer over something that has
paint on it without discoloring the light color?
I want to get away from tung oil for my next piece that has light pink painted parts but lacquer on Spanish cedar needs a sealer to coat evenly
Is this making sense?
I need to spray once piece is all assembled
I want to keep it as simple as possible
Any advice is appreciated
I'm painting Aspen light pink for next piece
Light color of what? The wood? The paint?
You can buy some wonderful sprays. I like to use Krylon triple thick gloss glaze for protection on some of my pieces. It does a wonderful job of coating the wood. I can't tell you what it will do over paint because the solvents might react. I suggest you try it on some test pieces painted and unpainted to see if you like the result.
If you like the look make sure you spray multiple light coats. Triple thick is no joke.
