- Thomasville, GA
Since I've been reading about Lightburn from a few of you, I decided to download the test version to try out a couple of things. I don't plan to use it to run my laser system; bCNC is working fine for that and I run that wireless. I'm mainly interested in how it handles photographs. It appears to be a snap for processing a photo, so I'm playing with it a bit more.
I ran into something that I haven't figured out yet, though. I did one photo, processed it, created the gcode, downloaded it to bCNC and ran it. The photo ran as expected, although I need to use better material for the final run. I read up on the settings information a bit more, then processed another photo. The second one caught me off guard because it printed upside down and mirrored! Any idea about the reversal thing?
In the process of running the second photo, I discovered I needed to tweak the driver for my X axis (long axis, two motors). I had set all the drivers on my J Tech BOB to 0.50V initially, then ran the X axis driver up to 0.80V. Everything I had run looked fine until I ran this photo today. Because of its transitions from dark to light and back, there were frequent accelerations, occasionally causing a blip in the motors. Depending on which way the axis was moving when this happened, the gantry would shift either right or left. So, after seeing that happening, I adjusted the X axis driver to 1.0V and ran the same gcode again. The results are below.
