Liquor Cabinet for a Friend
I apparently did not rub down aggressively enough on these pieces so I will have to give them at least another 24 hours to cure. It,s one of those things where you have a window about 20 minutes and if you miss it, you have to wait 48 hours.
Other panels getting additional coats.
The upper carcass getting its initial coats.
And I still have to address this beast.
It is not all that large. It just has a lot of elevations and I keep putting it off.
So when I apply this mixed finish I walk away for about 20 minutes (thank you phone timer) and then come back and wipe it down. The resultant amount of finish wiped off looks about like this.
The finish in this case is my usual plus some black dye. I also up the mineral spirits to get the dye to seep deep into the material. I am not using any Japan drier or additional metallics as the weather has been dry and hot lately. With this kind of mix you do need to keep the finish well mixed. I tend to shake the pee-wad out of it before uncapping. then I use a Popsicle stick to keep things mixed as I go along.
I also learned long ago (you can watch numerous YT videos on this) that high VOC materials create their own temperature when they cure. Don't be one of those poster children for spontaneous combustion due to oil conversion tragedies. I keep a pail of water nearby and toss my spoil in there. I always put the lid on before leaving the shop for lunch or whatever.
I haven't used these for a while but they have a storage spot over under (wait, is that a line from the movie 'Airplane'?) the saw horses.
Look Ma; I'm on top-o-the world!
At any rate, an assembly of various shop fixtures lets me support this carcass at a good height for working.
I encourage everyone to make shop fixtures that will help you out, store efficiently, and do double-duty.
Cue Bill and Ted's Abraham Lincoln . . . "Party on Dudes!".
I noticed your knock-down assembly table has 'ears' on the uprights that are not shown in the shopnotes article (congrats to you on the publication). Do you put these down to the floor or up to the top? Or should you have 'ears' on both the top and bottom? and I will be making a set for my shop ... thanks for sharing.
Dealing with some appliance issues but, let's get back to the fun stuff. You would think with all these shorts and cut offs I would have one lousy piece of Peruvian Walnut that I could get a couple of handle blanks out of . . . nope :D .
I did pick up a piece of purple heart that I will use for a bit of inlay on the pulls as the unit will go against a purple-ish accent wall.
I pull a piece of Peruvian Walnut out of the rack and select a section.
Here are my pulls.
I was never a very good student and sometimes layout can make my brain hot.
One of the weight plates I use as a hold down turns out to have just the radius I am looking for.
There will be a couple of 7/8" Forstner holes that will get connected to the outside world via the bandsaw.
I set up some stops that let me do all the holes pretty quickly.
So I end up here. The smaller arc is just free-handed in.
There will be some more machining before I cut the arcs. This will be a groove to allow the purple heart inlay to set in.
I cut some purple heart 'slips' to use as inlays. The low profile stop comes into play.
I cut the grooves in the blanks before cutting the arcs. I notice that I cannot get the inlays to fully seat. The light bulb goes off . . . I have a glue line rip blade that has a triple chip grind tooth in the pattern, the other is FTG. I was using the triple chip grind blade. This leaves a ridge that is of no consequence on a through cut but for grooving??? . . . Not so much. Fortunately I had a 3/16" cutter for my router plane on my Christmas list years ago and my daughter came through.
Flattened the bottom without issue and glued in the slip.
I have a pair of twin screw vises on the bench and used them to assure a warm loving hug on these parts.
Once the arc is cut, if things are not well seated it is on display for all to see.
The lower carcass has gotten a second coat. Shellac inside. Oil:varnish blend outside.
His buddies are on their last coat.
Final assembly is at hand . . . OK, I'm exaggerating . . . it will be several days yet. I love the look of oil blend finishes but, they cure by chemical process. That is a double edge sword . . . on the one hand they will not wait for you so be diligent. On the other hand they are done curing when they are done and all you can do is wait or find something else to occupy yourself with :D
I rip off the excess for the inlays. I didn't purposefully make these this much oversize. It just happened to be the thickness of the blank.
I put the cut offs in a drawer I have for random small exotics and figured material.
When setting the inserts I am always concerned about blowing out the "show" side. There are a few ways to take care on this. I can measure the height of the insert.
Thereby giving me a telltale on the tail of the micrometer.
If this fits the depth without exceeding the layout, you're good.
If you really trust your depth stop you can just use the hardware to set the depth.
Of course you always de-energize your meat eaters before getting your pinkies into the danger zone.
Once unplugged I use the drill press manually to set the inserts. This helps me assure that they are square and perpendicular to the material.
Ta-da . . . I really need to stop saying that.
I rough out the other waste.
A trip to the spindel sander brings me in to the line and a trip to the router table rounds things off. I end up here.
And in position it looks like so,
The door does not have the final finish coats on and will darken for a better match.
This poor thing has really been dragging on. In my defense some rainy weather (super rare around here) and a lot of birthdays and anniversaries have created breaks in the flow. I mean we just had a big get together and there is another on the 9th and one on the 11th. Then Thanksgiving and we roll right into Christmas. I am not complaining. I love the fellowship of friends and family. I just really want to get this thing done before the holidays set in ;-)
I've gotten pretty good at guessing how much finish a project will take. I will use this last couple of ounces for any touch-up after assembly.
I am taking care of a few details today. The top fasteners for the upper cabinet go on.
Here's one of those things you do without really thinking about it. Since I do a lot of pre-finishing of some components a bit of marking makes things go back together more easily. For example, I use a striking knive to mark the centerline of the upper cabinet and its top at the rear of the piece. I mark the line with a fine point felt tip pen. When the final assembly occurs you just line up the marks and screw it down.
And you end up here.
I just realized I already posted the pulls but, here you go again.
The little shelf that will stand on top of the lower cabinet and inside the alcove created by the upper is not attached. This lets the client position it left, right, or center as they see fit.
I put some low profile stem bumpers on the bottom of the side panels to keep things from sliding around or marking up the top surface. That's about it for now.
Grrr . . . I went out this morning expecting to start final assembly. I had laid the upper cabinet face down to do some final details on the back. I was not diligent enough about assuring the surface was clean. There was a bit of schmutz on the surface and of course the front leg sat right on it. While I happily moved the upper cabinet about while putting the finishing touches on the back (that no one will ever see anyway) I scratched the front of the leg up pretty good. I sanded it back and reapplied the finishing protocol. All will be well but I just cost myself a couple of extra days :mad:
