Stuart Ablett
- Tokyo Japan
I have a good client here in Tokyo that has a house in a very expensive part of town, where every inch of space is a premium. They have a garage on the first floor of the house that has a shutter at both the back and front of the parking spot. The back shutter opens into a small triangular-shaped area that is 3.5 meters by 2 meters by 3.1 meters. There is a concrete block wall on the property line, and behind the house is a small alleyway. They want to use the spot to park their electric bicycles, but they cannot get the bicycles past the parked car. They wanted me to put a door in the concrete block wall.
To do this, I'd have to cut the doorway, build a metal frame for the door, build a door, and move two air conditioning units up out of the way.
We were doing a bunch of other maintenance work on the house as well, and it was HOT, 40C or 104F, and humid.
This is looking at the area from inside the garage
Looking at the wall from the alleyway
The idea, a door, two aircon units mounted on the wall, and a roof, eventually.
I built the door first
Its built from Batu wood, kind of like IPE but not quite so heavy or dense and about 1/3 the cost.
I even bought a dowel maker so I could make dowels out of the same wood
Glue up time
Nice tight joints
I put a piece of the back to help keep the door panels from rattling
Finished with outdoor UV Osmo oil
These will be come the bracket to move one aircon unit up off the ground, but there are some pipes on the wall I need to avoid, so the brackets move the unit out from the wall
Two of these will become the door frame
The inside door fram in place where we will cut the hole
I put two pieces of angle iron bolted through the wall to stabilise the top of the wall.
Here is the stand-off bracket for the one aircon unit mounted
This is the second aircon unit mounted on its wall bracket.
And the first aircon unit mounted on its wall bracket, which is mounted to the stand-off bracket I built
Both aircon units are up and out of the way, with the electrical, drain and refrigerant lines all re-connected.
It was then decided that the door had to be a step higher than the alleyway surface.
This house flooded during a very heavy rainstorm a year and a half ago. Lots of damage.
Therefore, it was desirable to have the door one concrete block higher up.
We removed the angle irons on top of the wall, and I went a bought this 3-meter-long 10cm by 10 cm structural steel tube.
I made some simple brackets for it to bolt through the wall, but first, I had to flatten the top of the wall, as it was rounded.
Here I am with my big Makita concrete saw, flattening the top of the wall.
The tube dry fit.
With the brackets attached and about two tubes of heavy-duty construction adhesive applied it was time to set the structural tube in place.
The structural tube is all glued and bolted in place.
Now I'm not worried about the wall falling down in the next earthquake!
Glue up time
Nice tight joints
The tube dry fit.
