larry merlau
- Delton, Michigan
I run soapy water, then plain water, and finish with denatured alcohol to remove any water remaining in the gun.Larry cleaning with warm sope and water right after you finish. Usually I'll run warm sope and water through the gun 1st.
When your budget allows, consider installing one of these. I've had this model in my shop since 2009. I see there are lower cost units available now.i dont have warm water just cold out there.. ...
Try acetone to see if that'll dissolve it. Acetone is an 'almost' universal solvent and works on 'some' acrylic paint products.cleanup is ok but i got a spot inside the rotation nut where the needle goes threw that i cant get to with a brush and its still white, wet rag and dowel still wont budge it this stuff sticks to anything well if you dont want it to.
