glenn bradley
- SoCal
I think I just put this one in here to show how you can use hand screws to lock larger items down to barely fitting work platforms(???).
I am using some tape as a story stick for the drawer heights and spacing.
I couldn't bring myself to spend the measly $20 for the Kreg 720 bench clamp when I had these Bessey Corner Clamp clamps available. Our shops tend to get crowded with one-trick-ponies. Sometimes they are necessary but I try to avoid them. At any rate, I bought the small pocket hole jig insert for 1/2" material and lo and behold the cam-clamp won't fully lock down . . . it hits my non-official clamp. Field Modification!!! Ground a bit off the top of the Bessey clamp.
Chiseled out a bit of the plastic grip pad . . . So, now we all know I would have been better off just paying the $20.
Presto, works great. I put in the bottom shelf undermount slides. For people who use these often I am sure they are a no-brainer. I only use them a few times a year so I find I have to re-learn a lot of things; face frame versus frameless, inset versus overlay, there are different calculations for all of these.
I make a bottomless drawer box and amazingly it worked out the first time. Now I have my actual dimensions and can carry on.
I go on the search for drawer front material that looks nice. Board number 5 wins the bake off. You can see that this board has been hiding at the top of one of the wall racks for a half a dozen years. It's finally his turn!
I use poster board "L's" to frame views of wood grain. This helps me isolate what I am looking at and make the decision process easier . . . for me . . . Of course I am out of poster board so I just grab a couple of framing squares and some tape.
The "window" let's me look at the figure in a more focused way. The material is thick enough that each blank will yield two drawer fronts. This view is OK . . .
But I like the aesthetic of this figure better.
Just a bit to the right is a nice bit of figure that will fit in the smaller upper two drawer front dimensions.
They may or may not end up being used as bookmatched.
Resawing material from the same board does give you color consistency and I am never sorry about that.
