Modern Bed/Nightstands in walnut
Goal one this weekend was to finish the M&T joinery for the bed rails. I clamped a square to mark out the edge of the shoulder
Then a few light tap on a chisel to give me a starting point for the saw.
I mark my cut depth
Using another square to sight along I use my pull saw to cut the shoulder.
Next I use a wide chisel to pop off successive bits of the tenon till I get to my mark.
Using a circle template I mark out the radius for the end of the tenon. Sometimes I just find it easier to round ovrer the tenon rather than square up the mortise.
I use a flush trim saw to back cut the corners.
Back to the chisel to slice back to the line
Clean up using some 150 grit and the 'shoe shine' method.
Good fit! A pass or two with a shoulder plane and it slides home like a piston.
Goal two was installing the bed bolts. Been putting this off because being that accurate makes me nervous. :rofl:
After plotting out where all the holes should go I drilled a very shallow 1" hole which matches the diameter of the washer. I did not drill this to full depth so I would have more 'meat' guiding the drill bit on its ling journey into end grain.
Next, on the drill press, I drilled the 3/8" shank hole for the bolt. I first drilled a 1/8" through hole. this marked the exit point for the larger bit allowing me to partially drill through from the inside of the mortice, then flipping the piece I completed the hole from the face - no blow out.
Next came the nerve-racking part - the long deep bolt hole in the end grain of the bed rail. Prayers having been uttered I charged on.
I made an additional guide that stood far back from the hole and used the bit as a drft pin to align the hole in the u=guide to the one in the leg. This essentially gave me about 3" of guide for the bit to get the hole started.
As I went deeper I removed the guide and then the leg to drill deep enough o capture the full length of the bolt.
Now, even the best laid plans go wacky so, rather than just trust the drill went straight I used some rare earth magnets to locate the bolt in the wood. I was pretty close with only a 1/32 or so deviation but even that would have been enough to keep the bolt from threading.
Then one more nail biter, the bolt hole which needed to be about 1 1/8" deep...in 1 1/4" material! I held my breath on each one holing the drill would not grab and pop through the face!
Last step back to the drill press to finish the hole for the washer and bolt head.
No nail biting emoji on the like button so I settled for 🍿
Looking pretty good! I had to drill some similar cross bolts for the rear jaw on my twin screw vice into the bottom of my workbench whilst upside down.. but that had a bit more leeway in the amount of failure slop allowed :).
Well, if I weren't so honest I could come off a bit "cooler". I thought I had just clicked a "like" in a hurry as I was not paying enough attention. Turns out I wasn't even paying that much attention and I apoplogivze. I have never been a big fan of the "like" button. I have always thought that if I had something to say . . . it was worth saying (lord knows there are enough people who wish would shut up). Having said that . . . (man I hate it when he gets in one of those blathering modes and can't stop himself) . . .
Nice job on the modern style. I have been watching this thread as LOML is after something a little more "modern" in style for the new MBR. I would, of course, lay it out in an overload of Greene and Greene including overhead lighting and wall sconces BUT, it is not to be and that's OK. :).
I like the clean modern lines. The varying elevations in the surface planes keeps things visually interesting without losing the modern overall look. Some items I have made on request look so IKEA to me that I fail to sign them :mad: . These are anything but. Love the look, the material and the overall feel of the group.
