- Springfield, Missouri
I have a mini-split that was hail damaged about a year ago. I need to replace that unit and will do a refrigerant recovery of it before disconnecting the line set. While watching some youtube on the process of doing that, I came across the following videos showing how you can vacuum down the refrigerant into the outdoor condenser unit as they do from the factory.
This could come in handy for someone that needs to move or remove a mini-split. Using this process vacuums the refrigerant into the outdoor condenser, you then shut the service valve(s) manually when reaching 0 pressure. The lines and indoor unit can then be disconnected, moved or removed, then go through the vacuuming of a reconnected line set and indoor unit and leak test before releasing the refrigerant back into the line set.
For a single zone:
For a multi-zone unit:
In the case of my damaged unit, I think the bent fins caused some over pressure and refrigerant conditions. I'll need to recover the refrigerant since I'll be replacing the unit, so I'll be pulling the refrigerant out with a recovery machine to a tank. Should I decide to re-use the unit I'll need to pressurize it with nitrogen, leak test and fix any found, and reload with new refrigerant (R410a) by the weight required, which is listed on the outdoor unit label.
For a single zone:
