Mike Stafford
- Coastal plain of North Carolina
Narra is an exotic in the same family (Pterocarpus) as padauk. Whereas padauk is reddish brown narra comes in golden brown and red varieties. When the red narra is discovered in the burl form it changes name to become amboyna burl.
I had to stop turning padauk as it had an astringent effect on my throat which means it could have caused my airways to close and that is never a good thing. So far narra has not had a similar effect.
The wood for these two pieces came from a piece of a stick I had set aside because of a large gash that messed up a significant amount of the wood in that stick. Once I cut away the damaged area I had enough for these two pieces.
The first is inspired by a Japanese bowl that I find attractive. This little bowl is 2 1/2" tall and 3 3/4" in diameter. This bowl is turned in the traditional form with a hollowed foot so that it can be taken in hand used for eating and/or drinking depending on it contents. Traditionally tableware was finished with multiple coats of urushi lacquer derived from the sap of a plant similar to poison ivy. The sap was boiled to destroy its toxicity and then applied in many coats to ensure a resistant and long lasting finish. My bowl has three coats of brushing lacquer.
The second piece salvaged from the damaged stick yielded enough wood to make a box. This box is 2 1/4" tall and 3 3/4" in diameter. The end grain was interesting but I decided to dress it up a bit with a piece of chattered African ebony.
