- Constantine, MI
You may have seen the beginnings of this in a “Friday” thread a couple of weeks ago. The first 6” of the sides was completely rotted and the bottom shelf had some rot at the ends and was very badly cupped. The T&G back was also rotted at the bottom. In essence, the whole bottom had to be replaced.
I removed the back and cut off about 8” of the sides. This allowed me to get above the rot and some splitting that was taking place. Turns out the entire cabinet is made from poplar a full 1” thick.
I fabricated a quick guide that allowed me to use a flush trim bit in my router to square up the ends and insure that my dimensions on each end were the same.
I milled the material for the side extensions and duplicated the scallop cut out at the base. Then I used a whole lot of biscuits to strengthen the joint (Thanks Ted). Later that portion of the end would also be attached to the lower shelf so I thought the biscuit joint would be strong enough.
Next installment - bottom shelf and drawers.
