So I started to assemble the the motors on the mounting brackets and ran into a little problem....the motors shaft size is 14 mm and the timing pulleys are 1/2 inch so tomorrow I will see if i can fine some replcements that have the correct bore of if failing that I'll just ream these out. Once thats done I can mount the motors on the machine frame.
I also did a preliminary panel layout, I still am waiting for a 12 volt power supply and a couple of relays and a main power contactor then I should be able to wire up the panel. If I can get all the parts tomorrow I may be able to bump the motors next week..
3
