New flare
No, not flair, flare caps. Since replacing the OEM bumper on the jeep, which wrapped around under the rear fender flares, the flares have looked unfinished. So I designed some caps for the flares.
To be a bit more accurate on installing the caps, I created a couple of drilling jigs. One for the inner wheel liner…
The other jig was to locate the drill holes on the weld flanges. To align each I marked the rear of the cap with tape, then aligned the jig to the tape.
Clamped the jig and drilled the hole. The jigs were designed for each side (driver/passenger), so repeated on the opposite side of the jeep.
The holes were drilled to 1/4”, then 19/64”, and some touch up paint added to the bare metal, before installing the automotive trim connectors
The installed caps…
