New Iron Horse Rockers
I've been working on a new version of the Iron Horse Rockers I built about 15 years ago, scaled down to come out of a 4x8 sheet of plywood, birch in this case.
This is the first proto-type, but will reduce the engraving for these motors to 1/8" deep rather than 1/4" as they are here.
The issue with my spindle sending and estop happened 3 times during this part of the job at the same spot. I finally reduced the speed/feed to about 60 ipm to complete this part. I tried changing a few of the settings on the vfd, but still no luck. I will check all my grounding tomorrow to see if maybe it's a noise issue with one of the estops. :dunno:
Tomorrow will be pocket cut-outs and dowel holes, then part cut-outs for the main body. I also need to work on a hose hanger as it was really starting to chip up that front edge of the plywood pulling across it.
Brent Dowell
Bummer about it stopping. I think you may be on to something with the noise from the VFD. I have issues at time with the noise from my vfd resetting my raspberry pi running octoprint. doesn't happen all the time, but every now and then with the vfd spins up, it resets it. In my case, once things are running it's all fine, but definitely a possibility.
Don Baer
hmmmm (knock on wood) I haven't had any issues. Unlike Darrell my VFD is not located in the same enclosure as the rest of the electronics
I'll check the grounds on the shielding, but I still think it's a vfd setting, caused by load, either a amp, volts, or rpm change. It always sends the stop at the same spots unless I slow it way down, then goes through and works fine.
Don Baer
Darren, is the shielding grounded on both ends, if it is that could be the problem, you only want to ground one end and make sure the other is not touching ground.
Lesson for the night, send everything to zero before starting new operations even if you're sure something didn't change. :rolleyes: Luckily all the additional holes will be located under other parts or were in the waste area of the board. ;)
With some tweaks, the next time I run this it should be about 1.5 - 2 hours total. I still have the other half of the plywood to mill out with the rockers, wheels, and other pieces.
I didn't check to see if this was a up or down cut spiral bit, will have to make sure I run it with a down cut next run to see how the fraying is. It's easy enough to knock off with the sander though. I'll cut all the parts out from their tabs with the HF plung saw tomorrow night.
No, only on the cabinet side. I'm pretty sure it's something with the spindle sending the estop when it's overloaded, it did it again tonight twice in the same spot. I finally dropped the feed rate and took a little lighter cut and it finished the whole job without issues. I'm sure I have a setting off on it, just need to find my list and run through them again.
I was watching some youtubes the other day and saw one with some cnc projects April Wilkerson did. She was using a multi-tool to cut part tabs out on her cnc and thought it was a great idea. I stopped by HF tonight and picked up another multi-tool to keep at my cnc since the other one stays in my tool chest for house projects.
I also setup my router with a pattern bit and trimmed off the tabs from all the parts, then went looking for some 5/16" dowel, but must have used it all up. However, I did have some #2 yellow pencils of the right size. ;)
Here is the mock-up of the body.
So has anyone else used these abrasive nylon brushes? I also saw them on a youtube the other day and they work great for cleaning up the fraying wood from grooves and tight spaces. This one was a 320 grit, but have some 240 grit ones on order (https://smile.amazon.com/gp/product/B082VW14M8).
Before...
After...
Lastly, I did get the rest of the rocker parts cut out tonight, about 7 hours of cut time total, should be able to cut that in half, if not more, if I can figure out my estop issue.
I've got some round-overs to do at the router table, then will start gluing up some of the layers and getting ready for paint on others. I found when I built the last two it's much easier to paint in some of the edges prior to final glue-up.
