- Springfield, Missouri
I've been in the process of setting up the new presses that Dad picked up this winter and needed a few accessories for storing dies and such. Found lots of holder designs are available on Thingiverse for this, but also came across this collator/feeder that someone posted.
https://www.thingiverse.com/thing:2504314
https://www.youtube.com/watch?v=EO8HuW9l8MQ
I started printing up the main body for one of the recommended motors Sunday night. It finished in the early hours today, about 27+ hours total.
I also printed up a collator plate last night and will print some for other size of calibers I have too after I get some of the other pieces made and things assembled.
This design uses a feeder die from Mr. Bullet Feeder and can use a few other parts from that design, but I'm sure it could be adapted to the RCBS or Hornady feeder dies as well. There is a feed tube to print that uses either a mechanical or light beam switch to trigger on/off the feeder motor when supply in the tube decrease or has filled. Someone has even come up with an inverter to flip the bullets nose down for running through a sizing press.
Cost for this build should be just under $100. A retail version runs in about the $500 range and up.
