Stuart Ablett
- Tokyo Japan
After some time with the workbench/SawStop set up I built a while back, I've decided that it just don't work.
Here you can see the old set up.....
I thought this was a good idea at the time, I was wrong, it does not work well.
It is too big, it takes up too much space, and I can only work from one side of the workbench, and each time I want to use the saw, I have to clear the whole thing off, don't work well...
I decided that I want the saw turned so the cutting direction is on the long axis of the workshop and I want a separate workbench.
I trimmed the rails down to 162cm/63" this should be an OK width, I had to cut down the extension table with the router insert as well.
One of the other reasons I was doing this was the DC on the SawStop just did not work well, I figured with a direct shot to the saw from the 6" hose it would work better, I'm sure it will, as this is what I found in the 4" DC pipe next to the saw.....
Yep, that pile of dust
No wonder the DC sucked on the saw
I have the SawStop basically done, now I need to buy the wood to make my workbench.
I'm going to make a Roubu or French workbench as described by Christopher Schwarz in his "The Workbench Book", like this......
He recommends Southern Yellow Pine, but I cannot find it here, to make a truly heavy duty bench out of say Maple here would cost me a lot, a WHOLE lot.
One wood that is close to SYP is Douglas Fir, and I found some!!
These are meant to be ridge beams, the top ones in this stack are 4" x 6" by 13' long and cost about $50 each, I think my workbench should be about 24" wide, so 4 of these beams laid side by side will be close to that, and a squared off piece for each leg, I should be good to go!
Should be quite the bench......
