- falcon heights, minnesota
If you got 20 years out of a belt on a Reeves drive lathe, I'd say that's a good run.had a good start going. got 3 of the bodies turned and finished. had the 4th one turned, and sanded, ready to be finished, when after better than 20 years of use, this happened...
So now you have a free weekend!...i needed a different belt altogether. ordered it up on amazon, got two more of the right size in kevlar. they will be here between the 11th, and 13th...
Sounds messyThe fix-it guy who is helping me over the phone said to spray a bunch of wd-40 on the shaft area and the pulley, and it should open up with the wooden wedge.
Is messy! But it's only sprayed on the shaft.Sounds messy
