Here are some of the photos i took today.
H]
The first is the old pump house. I had to support the one corner while I took The corner support out to dig the trench to the well head.
Next is the new Well cap. The old system just came up inside the building to the pressure tank and then went underground to the house. Pipes always froze so now its all buried 2 ft below frost level. Next spring the building comes down.
Nest is the discharge drain for the new water softener. Too much salt during the flush cycle to put in the septic system so will do a couple of 90s and bury the pipe once the siding goes on next spring.
Next is inside the new mechanical room with the hot water tank, pressure tank, filter and softener tanks. everything is strapped to the wall as a sismic requirement. ( waiting for "the big one" to hit)
Then the wood shed I built in the rush to get all the winter wood in. ( one of the main reasons for my back issues)
Next is the first wall rack loaded with materials. Still lots more shorter stuff I need to build a rack for.
Shop is a disaster while I get everything done. This is the shot of the Ducting coming through the wall from the DC room ( an outside well insulated sound proof room). Two take offs right away for band saw and planer.
Last is one of 6 boxes of DC ducting parts. I picked up from a guy who was down siding his shop and took all the DC out. Sold for 75 bucks spiral ducting fittings and blast gates. Now its figure out where to use what.
