Bill Satko
- Methow Valley
Some time ago I was gifted with an old wooden smoother that had seen better days. I had helped some friends install a new hot water tank and they gave me their father's hand plane that had been sitting around unused for some time. He wasn't really a woodworker so I believe that he only picked it up as shop art much like you see shops decorated with large timber saws. So who knows how long it went without being used.
The blade was very tightly wedged in the plane and was a bear to remove, but I prevailed. The blade was not badly rusted, but I popped it into some rust remover and then flattened the back of the blade and put a new bevel on it. I also freshened up the chip breaker edge and ensured it sat flat against the blade with no gaps.
The body was very dirty but cleaned up with some scrubbing. I flattened the sole. The mouth opening is large for a smoother and I am thinking of patching the mouth to narrow the gap. Although the iron beds "okay", there is some funkiness' to it so I will ink the iron and wedge with dry erase marker, bedding them in the plane and then remove any high spots that show up with my plane floats. That being said, the plane cuts well.
The plane is an Ogontz number 3 smoother. Ogontz according to sources on the web was a “house brand of Sandusky Tool Co". It is a bit larger than my Voigt Coffin Smoother. It has a 2" wide blade and is 7-3/4" long. Both dimensions are 1/4" larger than the Voigt.
![1710261897761.png 1710261897761.png](https://familywoodworking.org/forums/data/attachments/117/117251-6a149ada68ae48464775924acf8180ce.jpg)
![1710261967384.png 1710261967384.png](https://familywoodworking.org/forums/data/attachments/117/117252-3fd999054548c0fd43116ed2faf2d3b1.jpg)
![1710262004167.png 1710262004167.png](https://familywoodworking.org/forums/data/attachments/117/117253-afa5f96ef2ea2280431c0af6a7504a72.jpg)
![1710262049398.png 1710262049398.png](https://familywoodworking.org/forums/data/attachments/117/117254-91418861f8d1ddabebe2a9861289074a.jpg)
![1710262122169.png 1710262122169.png](https://familywoodworking.org/forums/data/attachments/117/117255-d85585922e73362a76b758e68687ce1c.jpg)
Also, that is not a crack that shows on the sole. It is only some discoloration of the wood.
