- Reno NV
Yep, I've got a few new pedals lately and decided to mount everything on one single board.Pedal board stand?
It's kinda bouncy, so should give me some extra lift!C'mon Brent, tell the truth. It's a ramp to get a better liftoff from a low stage when you're crowd surfing.
Painting it black. It's a mix of pine and ply scraps. If I'd made it all out of cherry or something, I'd probablyleave it natural.Looking forward to seeing it once it's all loaded up with pedals. Are you going to keep it natural colored or are you planning to paint it?
Yep, The pine was surprisingly softer than the ply. I had even gone to the effort to predrill the holes with a countersink bit on the drill press, lol. I had the clutch very light and it still over drove in there.I see where you over drove a couple of screws. I noticed as I just did that the other day on a project. I was bouncing back and forth from drill to driving and forgot to change the clutch. With soft wood it happens in a blink of an eye. When you do that 3 time in a row you begin to doubt your intelligence. Two were so bad and visible that I removed the screws and filled in the holes with some dowels that I had on hand that fit perfectly. I then installed the screws and you can't tell. I would not have bothered but it was at eye level and you could not miss it.
That's kind of why I did this. A lot of these pedals come on automatically when they are plugged into the instrument cable, leading to a lot of dead batteries, or just a hassle to turn them on and off.Ahhh, for the days when the only switch we had was on/off and the only knob was volume.
