- Thomasville, GA
When I print a scale drawing for a bandsaw pattern, SU consistently covers more pages than necessary. Example: I print a pattern that is 19" long on letter size paper in landscape mode that should easily fit on two sheets of paper. No matter what I do, it centers the drawing across three sheets, with a small amount on sheets one and three. ???
Another issue (that I found a workaround on the SU Forum) is in Print Preview. When going to PP after setting up a scene, there is no dialog in the blocks. The workaround is exiting to Printer Setup, choose a different printer, to back to Preview, fill in the dialog as needed, choose the desired printer, then Print.
Part of my problem might be that I'm still using SU2017 - really not interested in doing everything online.
