Alan R McDaniel Jr
- Victoria, TX
I thought #1 wife could use a bowl to put Fall decorations in. I had a chunk of fresh cut Pecan so I hit it pretty hard with the Lancelot Tool and the chainsaw. After I got it roughed out (and it was very rough. The Lancelot tool doesn't like green wood), I use a Warrior 24 grit wheel the a stiff wire wheel then smoothed it with a softer wire wheel. I stained it with cherry stain and put a coat of satin spray poly over it for drill. I burned all the "hairs" off with a propane torch and called it good.
Most important part.... She likes it. Not bad for a couple hours work.
Alan
Alan
