Tom Harlos
New member
- Ontario
I have a 24 inch variable speed old Delta scroll saw but am having a hard time finding blades. Does anyone know where to buy these? Thanks.
Since the saw didn't have any blades with it, as I picked it up from a very old guy who had not used it in years, I am not sure what kind of blades it used. I did take a look at the clamping jaws. The upper and lower jaws look like they just clamp on but the lower jaws have a small vee groove cut in them from left to right. So what kind of blades should I buy? Thanks again.Need more info:
Are these pin-end blades, or blade with no pins? (no-pin blades are readily available, but pin-end blades are getting hard to find.)
What about blade length? Will coping saw blades work, or does the scrollsaw use shorter ones?
BTW, Welcome to the forums, Tom!
Hard to tell from your description. The vee groove sorta suggests pin-end blades, though.Since the saw didn't have any blades with it, as I picked it up from a very old guy who had not used it in years, I am not sure what kind of blades it used. I did take a look at the clamping jaws. The upper and lower jaws look like they just clamp on but the lower jaws have a small vee groove cut in them from left to right. So what kind of blades should I buy? Thanks again.
No I have not, but will do. Thanks.Did you look into https://mikesworkshop.com/
Thanks Paul, I will check out the site.There a several places to get blades that are all good. Here is a good list of them and other items for scroll saw stuff.
Suppliers
Browse our user-submitted scroll saw supplier directory. Explore real experiences and recommendations for scroll saw tools, supplies, and materials.www.scrollsawvillage.com
This also an excellent forum to get info on scrolling, and lots of free patterns.. I highly recommend doing some research on this site, and join and ask questions. Will save you a lot of frustration and shorten the learning curve....
