Bill Satko
- Methow Valley
The box was entirely made with the use of hand tools.
This is a small box about 12"L x 4-3/4"W x 4-3/4" H. It was made out of 3/4" thick common pine from Home Depot that I had left over from another project. I had cherry picked the wood from a stack of worthless pine but still had to carefully layout the stock to eliminate knots and other defects.
The sides of the box are 1/2 thick; the lid is 1/4 thick and the bottom is 3/16 thick. The sides of the box were laid out so that grain runs continuously around it. I will show more pictures of the finished box later in the thread.
The sides were joined using mitered through dovetails. The mitered portion of the dovetail allows for the plowing of a groove for both the bottom and lid without having to plug the resultant hole that you would get in a normal through dovetail. Below is a test joint that I did before building the box. The mitered portion on the box's actual dovetail is much larger to accommodate size of the plowed grooves.
The stock for the sides were prepared to the proper thickness just using hand planes but the wood for the lid and bottom were first resawed using a hand saw and then finished using hand planes.
Here the are sides at final dimensioning prior to marking and cutting out the dovetails. I left the thin lid and top stickered and with some weight on them while working on the sides.
With side dovetails cut out but without the mitered portion sawed or trimmed by chisels, I am plowing the grooves with a plow plane.
After roughly cutting out the mitered portion of the dovetail joints I finish it up with chisels using a paring block.
As I mentioned in another thread, my glue out was a bit of a struggle with a poor clamping plan by me. The joints all looked perfect during dry fit up but after glue up I had one joint with a gap. Wondering how to fill this gap my eye wandered to some wood shavings and I thought why not. This picture is of the shaving I first looked at seeing if it would work. I had to create a thicker shaving with a block plane but it worked perfectly and you can't tell there was ever a gap.
More later...
More later...
I don't have the skills to make something like that with hand tools, nor enough years left on this rock to develop those skills.
