Bill Satko
- Methow Valley
Inspired by Darren Wright's post about his Sawmill Tool Storage Shed and desperate for a single place to put most of my construction tools, I also bought a metal shed kit. I have to rebuild two decks and also hope to build an outbuilding or two starting next spring. Currently I have tools spread around in different places and not in very accessible locations. Any project becomes an exercise in trying to find Waldo. I speed more time trying to find something I know I have, but not clear as to where I rabbit holed it away at. Also, I need a space to put the various tractor maintenance and spare items that I have just been dumping into a Knaack box.
I went with the Veikous 10'x6' metal shed which I got from Home Depot. Ideally larger would have been much better, but I was limited in the space I wanted to put it and it had to be a mono slope roof to fit the style of the house. It will do for now and later I have plans to move it and it will just be for tractor items.
I roughly laid out where I wanted to over excavate the holes for the deck blocks I was going to use. I used the tractor's backhoe to dig this and compacted them with road base before placing the blocks.
The actual floor that I am building for the shed is going to sit on 4"x6" pressure treated skids which will allow me to move it in the future.
The floor was framed using 2"x6" pressure treated and was secured to the skids using Simpson A23 Angle Plates. Prior to framing out the floor I backfilled and leveled out the area with a top course (3/4 rock with fines) that I had delivered for some parking and road work I am also doing.
I used 3/4" tongue and groove waferboard for the flooring.
Before installing the metal shed's base plates I decided to lay a perimeter of 2"x4" for this base plate to sit on to gain me another 1 1/2" in height. Although I will need to build a slight "ramp" to wheel things over the threshold this added 1 1/2" will prove to be a godsend. I had some flashing so I sealed everything.
Later, the assembly of the shed.
But man, those views are just incredible
