- Springfield, Missouri
I came across my handout from Burning Wood, has some good info...
Part 1:
Heath Hazards
Safety
Basic Tools
Additional Tools
Chemicals
Types of glass
Cathedral & Opalescent
Textures/Patterns
Antique
Seedy
Streaky
Textured
Baroque
Glue Chip
Water glass
Crackle
Dichroic
Iridescent
English Muffle
Ring Mottle
Whispy
Nuggets & Jewels
Manufacturers
Armstrong Glass Company
Bullseye Glass Co.
Profusion Glass (Dichroic Glass)
Lambert Antique Glass This glass is from Germany.
Kokomo Opalescent Glass
Spectrum Glass Company
Youghiogheny Glass
The Paul Wissmach Glass Mfgs
Uroboros Glass
Part 1:
Heath Hazards
- Cuts
- Glass Dust (Silicosis)
- Lead Fumes
- Acids
- Burns
Safety
- Wear safety glasses
- Never grind glass dry, always wet
- Don't slide or roll your fingers over the edges of cut glass
- Work in a well ventilated area when soldering and working with chemicals
- Don't run with glass or scissors
Basic Tools
- Safety Glasses
- Cutter
- Pistol, Comfort Grip (straight), Toyo custom (Hybrid)
- Self Lubricating or dipping jar/pad
- Lubrications - Cutter oil, Kerosine, mineral oil, 3-1 oil, etc
- Breakers
- Grozers
- Nips
- Foil Fid
- Grinder, carborundum stone, or Hand Pad/Stone (wet grind always, never dry)
- Glazing Hammer or hammer
- Nails (horse shoe) or Tacks
- Layout board, typical size: 24" x 24" x 1/2" particle board with 1" x 2" attached on left (or right) and bottom sides squared at 90* to one another
- Latex or Nitrile gloves
- Scissors
- Glue Stick
- 80 Watt to 100 Watt Soldering iron
- Solder, 50/50, 60/40, 63/37, or lead free
- Disposible flux brush
Additional Tools
- Needle nose pliers
- Wire cutters
- Wire Twisters (aviation safety wire pliers)
- Ruler, Triangles, Squares
- Waffle Grid or Morton Glass System
- Lead Stretching clamp (Lead method)
- Lead/Foil Pattern Scissors
- Whiting brush (Lead method)
- Thumb/Finger pads/protectors
- T-Square
- Light box
Chemicals
- Flux, liquid or paste
- Cutter Lubricants
- Glue Sticks
- Mirror Edge Sealer (if working with mirrors)
- Patinas (foil method mostly)
- Flux Removers, dish washing detergent (not soap) works great, but baking soda and water also work.
- Waxes (foil method)
- Glaze (lead method)
- Whiting (lead method)
Types of glass
- Cathedral glass is clear glass that you can see through. It comes in any color you could think of. It can have a texture on one side, or be smooth on both sides. It can be swirled or streaked with another color of cathedral glass.
- Opalescent glass is glass that you can't see through. As with cathedral glass, opalescent glass comes in every color imaginable. It can have a texture on one side. It can be streaked or swirled with one or more colors of opalescent glass.
Textures/Patterns
Antique
Seedy
Streaky
Textured
Baroque
Glue Chip
Water glass
Crackle
Dichroic
Iridescent
English Muffle
Ring Mottle
Whispy
Nuggets & Jewels
Manufacturers
Bullseye Glass Co.
Youghiogheny Glass
Uroboros Glass
