Sweet Bedroom Suite
Rennie Heuer
Constantine, MI
I fit the drawer faces to the large dresser today. I first laid out the holes for the hardware using a jig and a punch. Holes were drilled on the drill press for accuracy. I then placed the fronts in place using spacers to keep everything aligned. Then I used washer head screws to temporarily attach the fronts to the boxes so I could drill for the permanent screws.
allen levine
new york city burbs
my garage shop is not insulated that well, and with the overhead door, theres plenty of outside air getting in when its closed, I have a 5200 btu unit in the window out there. the garage is 320 sq feet. when temps hit up to 80 degrees, if I turn it on at 7 am, by 10 or 11 I can go out there fora few hours before it gets too warm again. I blow the circuit breakers when I have everything on in there. Planer and mitre saw seems to trip the breaker the most. but its become a routine for me, turn on the planer, shut the ac off for a few minutes.
Rennie Heuer
Constantine, MI
Finally!
Here are the last two pieces in the bedroom set I have been working on forever! This 9 drawer chest weighs a ton. It will be nice to see this go and regain some real estate in the shop. I think the grain matching on this one went well, I cant even find the joints on the drawer faces, but there are 3 boards there. Last bit to do was the matching mirror frame. That just needs some varnish and I can get the glass installed.
glenn bradley
SoCal
I would be thrilled with those drawer faces. It really does look like the sort of seamless field you can usually only get with blah figured material or veneers. Wonderfully done!
I get you on the weight factor. I too have a tendency to build strength via mass. I am working on a Buffet/Sideboard sort of a smear piece for our dining room. I have re-worked the design several times trying to shear off weight, replacing it with method. I'm also trying to factor in a lot of Domino's to justify the ridiculous price of that thing :D. I feel like I am forcing them in as other methods are actually less work.
Sorry for the near-thread-jack. Mind wandering. Bored. Need shop.
