Table Saw Blade Query
Chris Hawkins
Beaverton,Mi
In an effort to advance my overall wood working skills I'm going to move toward higher quality equipment. With that in mind I know I need to upgrade the blades for my table saws, I have 2 set up, so my thinking is this. 1 saw has a zero clearance insert, this will be for more intricate cutting, the other for more generalized cutting.
What are some quality blades for each saw?
Thanks...Chris
  • Short list:
    Oshlun - not a lot of direct experience but good reports
  • Tenryu - I use a Tenryu ATB grind, .128 kerf blade as my "all purpose" blade, the cut quality is fantastic and the life is pretty decent (depending on the wood).
    Forrest - My dado set is from here and I've used some of their other stuff previously. I think the quality is close to par with Tenryu but the Tenryu price is perhaps a smidge more attractive on some blades (still not cheap as such).
Any of those are in the "send them out to be sharpened" price range which drops the initial $$ hit a little over the life of the blade.
Some of the Freud blades are pretty decent as well. They have a thin kerf combo blade that's generally fairly well liked. I'd have to have it re-bored to fit on my saw so haven't tried it but it might be an option for your detail saw.
I'll have yo go out to the shop to get the specific model numbers, but I'm a big fan of the Freud Industrial Thin Kerf blades. I have a couple of the rip blades and one of the cross cut blades, and have been very happy with both models. Excellent cut, durability, and price.
freud, luco, forrest, but on thin kerf blades you can do your self a favor by getting a blade stablizer for it. the freud glue line rip blade 40 tooth is one of my go to blades. and getting them reground is a cost savings. i even had the forest resharpened b another company. sending them in was a pain and if you can find a good sharp shop your time and money ahead. to be setup well you need to have at least 3 different blade with different tooth count. 24-40, 60, and a 80 to 100
I've mostly used Freud thin kerfs myself. I'm considering going with the "What would Glenn Do" school of thought and buying all my blades ground at exactly .125" (1/8") kerfs. Glenn talked about it at Burning Wood II a couple years back and doing so makes complete sense for layout of material, dado widths, and general calculations since you know the kerf is exactly 1/8".
I've used different brands over the years, but settled mostly on Freud - for a while
Thin-kerf blades were my choice until I realized they wouldn't always cut like a blade should. When I transitioned back to full-kerf blades, I was much more satisfied with the results.
A few years ago, I needed some new blades and did some research. I found a brand I hadn't heard much about, delved a bit more into them and bought this set from Infinity. Best thing I ever did! As received, they were sharper and made cleaner cuts than anything I had used before.
Another vote for the Freud thin kerf industrials. I have both the glue line rip and the 80 tooth crosscut/plywood blades. Both perform very well.
Was given a couple of HF blades, so ok I'll try them out. After cleaning and installing on my Unisaw tried cutting 4/4 oak, I have never seen so much smoke in such a short time and the vibration was something else. TRASH!
Sent from my SM-G960U using Tapatalk
