Tablesaw Safety
Dave Richards
SE Minnesota
While I was out tuning up my tabelsaw I thought I'd take some photos of a safety feature I added some years ago. Hopefully someone will find this useful.
As we all know it's a good idea to disconnect the power when doing things like changing blades. Instead of getting to the outlet and unplugging the saw which is a pain, I added a service disconnect box on the saw where it is easy to reach.
I wired a single receptacle to the back of it and plugged the saw into that.
The box is designed for 240V service but my saw is 120V. I wired both the hot and neutral through the disconnect so only the ground goes through from the saw. Although I don't have to worry about it in my shop, I figured if I ever sell the saw to someone who happens to have reverse polarity outlets, this will still provide protection. (I've seen several shops with reversed wiring around here. :rolleyes: )
This isn't a permanent modification to the saw so it's also easily removed if I needed to do that.
Dave Richards
SE Minnesota
Thanks Ken. It's pretty easy and, at least for me, encourages me to practice at least one safety thing. Still no guard over the blade, though. :D
FWIW, once in awhile I do ground integrity testing on my machines. It doesn't happen very often but over the years I've found the need to improve the ground connection on couple of machines. This is a hold-over from my biomed days.
Dave Richards
SE Minnesota
Thanks Vaughn. It's still kind of low on my saw because I didn't want to make any real modifications to the saw but it could fairly easily be mounted closer to the power switch to make for even less bending.
I don't know why but the floor has gotten lower and harder to reach than it once was. And when I fall down, it's a much longer climb back up. :lol:
Ken King
Bridgton, Maine
What saw is that, Dave?
If I could do anything to improve the safety of my saw I think it would be adding a riving knife. If I still worked with machine tools I would have made one by now. I did move the power for the saw to a drop at the right rear corner so it's easy to unplug, and I added a paddle switch, anything else is going to be bigger work I fear.
Dave Richards
SE Minnesota
Ken, it's a Jet contractor saw. I don't have a power drop in my shop and the tablesaw is kind of in the middle so I have to run a cord from a wall.
I wish I had a proper riving knife. I do have a splitter mounted in a throat plate. You can't see it in the pictures because I was switching to the cross cut blade and then my sled would go on top.
Ken, I have the Microjig splitter on my Ridgid contractor saw. It has worked great for me. I use various Freud thin kerf blades (which I also highly recommend), so I have the yellow splitter set specifically for thin kerf blades.
And Dave, I recognize those Incra rails on your saw. I love my Incra fence setup. :thumb:
Ken King
Bridgton, Maine
I think I'm just going to have to get the microjig setup. It does concern me that there's nothing back there, not even a splitter, and the saw certainly has enough power now (5hp) so I won't be stalling the motor, making me a tad concerned about the possibility of a kick back.
Dave Richards
SE Minnesota
Vaughn, I like my Incra fence, too, except for the space it takes up when I shift the fence all the way to the right. I see guys with the right end of their say pushed up against a wall and I wish I could do that.
I did add a tray between the rails off the right wing that is extremely handy. It's nothing more than a piece of 1/4 in. ply cut so it slides into the channels on the inside of the rail. I added a couple of of scrap about 3/4 x 1 as stiffeners and to keep stuff in the tray. Very useful and again, not a permanent mod.
Ken, definitely do something for a splitter if you can't add a riving knife. Mine is a thin piece of maple in a shop made zero clearance plate.
Dave, I'm with you on the space the fence takes up when the fence is all the way to the right. The way I have my rails set up, I can only move the fence about 20" - 21" to the right of the blade, but I can slide it all the way down to the other end to use on my router table extension. This pic is before I had remounted the power switch for the saw.
I eventually added a couple of adjustable braces to help support the extension. I also eventually swapped out the PC 690 router for a Hitachi M12V.
