Dave Richards
- SE Minnesota
While I was out tuning up my tabelsaw I thought I'd take some photos of a safety feature I added some years ago. Hopefully someone will find this useful.
As we all know it's a good idea to disconnect the power when doing things like changing blades. Instead of getting to the outlet and unplugging the saw which is a pain, I added a service disconnect box on the saw where it is easy to reach.
I wired a single receptacle to the back of it and plugged the saw into that.
The box is designed for 240V service but my saw is 120V. I wired both the hot and neutral through the disconnect so only the ground goes through from the saw. Although I don't have to worry about it in my shop, I figured if I ever sell the saw to someone who happens to have reverse polarity outlets, this will still provide protection. (I've seen several shops with reversed wiring around here. )
This isn't a permanent modification to the saw so it's also easily removed if I needed to do that.
