- Springfield, Missouri
So I'm looking for a solution to leveling out the ceiling in this space. The outer walls are sitting on a foundation that isn't quite level, I'm seeing about 1/2" in elevation changes from one side to the other of the room and even a drop from front to back. To compound the issue, the trusses were built using green rough sawn 2x4's from a local mill, so as they dried, they've warped and twisted a bit.
I originally was thinking I could just cut the nails on some of the truss ties and jack up and manipulate the bottom cord to where I need it to be, one truss at a time. The more I thought about that the less I was liking that idea. I'd be fighting stresses from the supporting trusses around it, and pushing and twisting a lot of things and potentially could mess with all the seals on the roof fasteners, creating leaks and such.
My next thought was to just do furring strips across the trusses starting with outside and doing shorter ones every 2' or so. This was leaving the screw spacing for the ceiling a bit far apart and may cause some warping in the osb over time. The other issue is that not all are sagged consistently, some are a steady curve then others twist and the cord board drops and inch closer to the wall end.
They are all consistent where they land in the middle of the ceiling though, right at about 2 1/2" lower than the walls. The walls are on a raised concrete wall, around the entire perimeter of the garage, so even with the sag, the ceilings are almost 8' in the center.
What I think might work is to scab in 2x4s from the end of the truss to the middle of the room, on each end of the truss. I'd notch out the wall end to the amount of sag I need to remove and attach the inner part level with the bottom of the truss. Trusses are on 2' centers.
Something like this is what I'm thinking.
I'd support the notched side from the bottom with either a 1x4, joist hangers (if I can find them that short), or the wall OSB panel.
Anyone have any thoughts about this or any other ideas to consider?
