For easier setting up and moving of these Dewalt 735 planers, they weigh 95 pounds, according to the literature that comes with them. My shop is small, so when I use it I have to move it outside in my driveway, but I have very little room to store it inside my shop too. I ended up buying a Delta Miter Saw/Planer stand that is now being sold as a DeWalt, but essentially the same, actually better than what I have. The rails for attaching the tool are too close together for the wide footprint of the 735 planer, so I made an adapter out of 3/4" Cabinet Birch plywood, adding holes for bolting on the 735 planer, then holes for attaching it to the rails of the stand. This worked very well and I can leave the planer attached to the stand full time. The design of this stand is much like a hand truck and it can stand on it's end while folded, so it only requires about 3 sq ft of floor space in the corner of my shop, even with the 735 planer attached to it. When I want to use it, I wheel it out of the shop to the driveway much like wheeling a hand truck with the two wheels at the bottom end and a handle at the top end. It's handle weight is much less this way, so even this 84 year old guy with 11 heart surgeries and metal knees can do it easily. When the hand truck is where I want to use it, I set the handle down on the ground, then lift the smaller handle just above the large handle and the scissors part of the frame opens, lifting the stand into it's up position. Gas spring cylinders in the frame provide much of the lifting effort and it is easily lifted up into it's working position. There is a height lock lever at the right end of the smaller handle and there are two height positions available. It will auto latch at the lower position as you raise it, but lifting and tripping this latch will let it raise to the second and full up position where the latch again auto locks.
There are two rollers (one each end) that can be extended out and up to support longer boards as they enter and leave the planer, but I found that the accessory extension tables worked better for shorter material, and they can be left in place when planning the longer material too, do my setup always includes both these tables as well as the extension rollers.
I have the DeWalt chip hose and fabric barrel cover accessory and use a 60 gallon plastic barrel for my chip collector. I store the barrel upside down behind my shop. The hose is attached to a fabric barrel cover that has a draw string to tighten around the top edge of the barrel, so the chips stay in the barrel and the exhaust air comes out through the fabric. This works well, as long as the draw string is tight. If it isn't, I discover chips everywhere, and my neighbor's swimming pool is just on the other side of the bushes, so I get to clean chips out of his pool too.
When finished planning for the day, I disconnect the chip hose and fold up the extension rollers, then grab the large handle and lift slightly while releasing and holding the latch lever. I can then easily lower the stand back to it's hand truck profile. I can then lift it and wheel it back into my shop and leave it all standing back on it's end in the corner of my shop. Most people don't need to do this next step, but my shop doorway is a bit narrow, so to avoid hitting the planer height adjust wheel I use the included, attached THandle Allen wrench to remove the one Allen head machine screw in the middle of the hand wheel, remove the hand wheel and replace the machine screw in the threaded end of the shaft. I have a Velcro Cable Tie attached to the hand wheel and use this cable tie to attach the hand wheel to the handle of the stand, so it doesn't wander away between uses. The dust hose accordions into a very short length and I stuff the fabric filter into the end of it. This ten all fits into a small cardboard box that I place on top of the planer when the planer and stand are stored on end in my shop.
This is the DeWalt version of my Delta Stand. It has a few improvements over my stand, and since I bought my stand about 20 years ago, the price is now almost 50% higher too. Present Amazon price is now $299, but if you are as old as me you will consider it very worth the money after you use it a few times.
DeWalt discontinued selling the dust hose/barrel cover for the DeWalt 735 planer, but when I last checked, Black & Decker was selling what looked like the same hose and barrel cover for a leaf vacuum that they were selling. It looked identical, except for the red/black color instead of Yellow/black. You will need some kind of chip collection, because the fan inside the 735 really moves the chips. Don't expect to collect them with a small hose and shop vac. You will plug the hose quickly. I can 1/2 fill a 60 gallon barrel in about 1/2 hour using the 4" hose and 60 gallon barrel.
Again, this collection hose isn't the same, but close to what was being sold for the 735 planer. The attachment fitting for connecting to the planer is the likely difference and will need a bit of DIY effort.
Buy BLACK+DECKER Leaf Collection System, (BV-006L) at Walmart.com
www.walmart.com
