Thinking about picking up a lathe.
John Pollman
Rochester Hills, MI
Hi folks.
I've wanted a lathe for years and have come close several times but never pulled the trigger. I've been spending like a drunken sailor the past few months on a CNC and upgrading power tools to Festool. However, I had a request from a friend the other day who knows someone looking to have some things turned. They are about 5-1/2" long and 2-1/2" diameter. (pic and diagram below) I probably already have the material to complete the job, I just need a lathe. I was shocked when he said that he wanted twelve dozen units! For that quantity, I'll need a duplicator. I've never used one, but learning shouldn't be too hard. Grizzly has a 14x20 with a duplicator for about $750. I'd be OK with that. I'm kind of leaning toward taking the job. I'd love to have a lathe anyway.
I mean.. I've picked up parts of mine.. but I didn't carry them very far :rofl:
That shape would be fairly easy to do on a duplicator, they don't do a great job of fine inside details. But for soft curves like that they usually work pretty well. The finish can vary somewhat depending on the cutter, I don't have a lot of experience there as I'm pretty much a traditional lathe tool user. You'd still need to trim/finish the ends in some way.
I might also offer the standard warning that lathe tooling is another slippery slope of pocket book emptying..
Besides just rotary, try 4th axis and A axis for search terms. As long as their software supports "wrapping' should be a cheaper option than a lathe, and more accurate on the duplication. If the Onfinity controller doesn't support an "A" axis, you can swap the motor connection with either X or Y, depending on which way you have the rotary facing.
It looks interesting, but something came into my mind: sanding/finishing. It'll be MUCH easier on a lathe. I think I'm going to go that route.
Thanks!
I've got the Grizzly sharpening system already. :)
Which one do you have? If it's their slow speed wet grinder (and if you get into turning bowl-shaped stuff) I'm pretty sure the Tormek gouge jig will work with it. Or for a typical bench grinder, something like the Wolverine jig or Grizzly's bench grinder sharpening system are what I'd recommend. Getting an even, consistent bevel on gouges is super important IMO. :thumb: There are a few guys who can get a good bevel on a gouge freehand, but they are about as rare as nine-year-old kids who can play Joe Satriani songs on a guitar. :D
It's this one.
It's this one.
Good choice. :thumb: You might find some worthwhile DIY jig ideas here.
