Sketch up users are familiar with the push/pull tool, in Fusion it is called extrusion. Basically what you do is take a 2d drawing extrude it into the third planes some would call it 2 1/2 D. In Fusion there is another more power full tool called lofting. It allows to two extrude between two sketch in two different different planes. with Push pull you create a second plane by pulling the sketch to the new plane but with the loft command you join them together even if they have different shapes. I used this command a lot while modeling submarine hulls and it can be vary useful for 3 D modeling. In this example I will create an adapter to join a 2 1/2 inch hose to a 4 inch square opening.
This would be useful for dust collector systems.
I start out by making a rectangle 4 inches square with 3/8 rounded corners in the X Y plane
Next I create a next X Y plane that is 3 inches in the Y plane away from the original
Now I crate a circle that is 2 1/4 inch diameter in the news plane.
now I select the loft command from the create menu
and select the surfaces to use. The loft command fills in the space.
