well, tell your friend that he will have a roughly 29" x 29" cutting area to play with. plenty of room for just about anything. he will have a workable depth of about 2.5". another thing, i've seen a lot of people needing to change brushes in the routers that they use, may want to keep that in mind. another thing is, is that the z axis is run by a belt, rather than a machine screw like my shapeoko2. they have come out with a replacement for it, called the hdz, from the looks of it, it is about the same set up as my shapeoko 2, but on steroids, its being sold as a replacement for the belt driven z axis set up. another thing to save money on, avoid this new bit changer gimmick, and the touch pad thing for setting your z axis zero point. you can change bits by hand with no problems, and a good old bit of paper (standard 20 lb for your printer works best), and it will get you to within a skinny cat hair, split seven times (0.004"). as far as software goes, don't go cheap with carbide create (free), lots of limits as to what it can do. go with vectric's vcarve desktop, very good software, i use it. the pro version only has a couple more bells and whistles, and if going to make and carve 3d stuff, spend the $1100 on aspire. i use universal gcode sender, and have no problems with it. other than watching your feeds and speeds (if you want to go fast, go shallow, with lots of passes), i would advise to start out with a few simple signs, and such, before getting into more complicated items. once he gets the hang of it, his other tools will get jealous, and start planning a revolution.... lol
