Wall Mounted Quilt Rack
glenn bradley
SoCal
A friend's sister does quilting. We talked about a rack back when I didn't have the shop finished and I completely forgot. Time to catch up.
Got the required specs from her and got approval on design number 4.
As always wood selection comes first. Like many materials, cherry comes in a variety of colors and figures. I found a couple of similar looking boards that will yield the parts.
Rough blanks.
I milled to thickness and general size. The shape of the end brackets will let me cut around some pitch pockets in these blanks.
I rough the shape out at the bandsaw. Clean it up a bit with some rasps and cut the bottom of the rail notch like you would dovetail waste.
This gets me here.
I have done a lot of Greene and Greene stuff. During that journey I picked up one of these double round overs. I find the 1/8" and 3/16" radius cutters handle most of what I need.
The bit comes with a variety of washer/spacers that allow setting for your material thickness.
I use a bit of scrap to set the height and keep the leftover washers in a bag that fits in the tackle box cubby assigned to this bit.
The purpose of the bit is to allow you to round both sides at once while always routing down hill. If you've seen much G&G style stuff you get why this is helpful. At any rate, I end up here. If you've ever wondered what you would do with a parrot vise, this is one thing. A little hand work and I end up here.
More to come.
allen levine
new york city burbs
I've made several quilt holders
Always use cherry but no where as fancy as yours
I keep the template for the walls so I can put one together if I want to make a quick project
Your design is much nicer but above my skill level
I believe I took a picture of Amish made hangers and just copied
glenn bradley
SoCal
Nice ones Allen. Yours are essentially the same and seeing your work I do not believe mine are above your skill level at all. I just had a few "gotta haves" from the client. I did make a hardboard template for the side/bar supports so I too can make others more quickly in the future. It is getting this thing shipped to Arizona that will be the stumbling block if anything.
Here's a dry fit shot, still in the rough.
Bill Arnold
Thomasville, GA
Great looking project, Glenn!
When I saw your post, it reminded me of the first project I ever made with something besides inexpensive pine: a wall mounted quilt hanger. As soon as I started milling cherry rather than pine, I never went back!
glenn bradley
SoCal
When doing long fair curves I find it best to bandsaw and rasp one, then use that to make a template, and do the other end using this template.
I happen to have a domino. Otherwise I wold probably have done this as a stopped groove with a spline.
I had to make a couple hundred mile drive this morning so I am done early for the day. I'll pick it up tomorrow.
Don Baer
this post reminds me of when LOML and I were still fairly newly weds. and LOML came out to my shop and asked me if I could make her a quilt rack and I said sure, what's a quilt rack. So after researching it I found several examples. Most of them had room for 3 quilts. I showed em to her and she said yes BUT she wanted one with 5 bars and a Drawer so I took the dimensions off of one and drew up my idea and she loved it. That was close to 40 years ago. It sits in my bedroom with about 8 quilts pilled on it.
Catalunya
I can see that once your new shop was ready, you went full throttle with ww. to catch up with all the pending projects. Good job on this one as it couldn’t have been different !
Frank Fusco
Nicely done. Quilt making and display is a far more popular avocation than many realize. These are good seller. There used to be a guy who made and sold many in the area. I never got into it because I felt our market was not big enough for two of us.
glenn bradley
SoCal
I will use a domino at the junction of the bracket and the top. This is more to prevent twisting than anything else.
I mark the layout on tape to make clean up easier. I clamp a scrap to act as a stop for the middle-o-the-panel mortise.
And she fits together like so; although still upside down :).
And now a PSA break . . . remember to unplug your tools before changing or handling cutters please.
I will use mechanical hangers and fasteners. The hanger mounting screws will go through the back and well into the brackets that support the weight of the payload.
cont'd . . .
glenn bradley
SoCal
You can see here why I left the rod as a rough blank.
This lets me mark right off the piece.
I settled on a 3/8" deep notch in the rail
I then knock the sharp edges off at the router table.
A little hand work and I am ready to start applying finish.
One coat.
Two coats.
Probably one more and then a paste wax.
glenn bradley
SoCal
My original design included piercings on the top trim. I moved away from this but now feel the look is too plain. I will add some ebony accents.
Don Baer
I think I would have routed a 1/2 grove on the shelf about 1/4 was from the back for a plate grove, I have seen that done before. I know it late for that but if you ever do it again, JMHO.
glenn bradley
SoCal
I asked about a plate groove. No interest from this client. Definitely something to include in a generic "for sale" item though. (y)
