Walnut Natural Edge Bowls
Southeastern Wisconsin
I thought the folks here might enjoy seeing these two bowls - they are both from the same crotch - the first division at the top of a black walnut tree. These were custom turned for the owner of the tree and I delivered them last Thursday. This was the hardest black walnut I have ever encountered.
Wow, nice work Tony!
I've got a walnut trunk waiting for the sawmill that has a similar growth, with two piths that merged like that. I certainly hope it's got some figure like that.
Very nicely done, Tony! :clap: You got a great finish on them. What did you use? Also, what are the approximate dimensions?
Thanks for all the kind comments. "Even a blind hog finds an acorn once in a while."
Answers to questions:
The wood was quite fresh when I received it. The tree was cut down in November 2021 so the bark had a natural tendency to stay stuck to the wood. I rough turned them in December, and then sanded them out in March and began to apply the finish.
I use Minwax wipe-on poly for these types of turnings, I use an eye dropper and let the bark soak up as much of the WOP as it will.
The bowls are probably 14 inches across at thier maximum width/length. I don't think I ever put a measuring tape on them. :unsure:
