Mike Stafford
- Coastal plain of North Carolina
I know that you are supposed to use water when sanding with silicon carbide sandpaper. When I am sanding bare steel the water seems to create a slurry of grit and metal. I also know that you use water when sanding bare metal and primer in preparation for painting on a car.
My question is why do you use the water? to float away the sanding dust? to float away the metal grit? to lubricate the sandpaper in order to extend its life?
I have also used water while sanding wood and wood finishes. I usually use water or some other lubricant to reduce heat generation on dense wood subject to heat checking.
